Battery!!!!!!!!!!!!!
colin129
I'm sure this one has been up loads of times.
My battery will last a week or so if I do not use the car, so I have been going for a run at least once a week to keep everything charged up and the oily bits moving over the winter.
Unfortunately I missed the last one, was away for a week over Xmas and now the battery is so flat that I could not even jump it off the Mundano (even with its high power diesel battery).
What is my best bet?
Some sort of trickle charge/conditioner to get some life back in the old girl. Which one would people recommend and where can I buy from.
Really p***ed off too as she was looking quite sexy in the winter sunshine and I was looking forward to the drive [:)]
How old is your battery? If you need a new one definitely buy a Bosch 'Silver' 70ah. You can get them from Eurocarparts or GSF for around £60.
Some Porsche owners use a battery conditioner from CTEK who supply OE equipment to Porsche. They cost around £50.
I bought a battery conditioner around 2 years ago from Aldi/Lidl for around £20. It is EXACTLY the same as the CTEK (the only difference is it doesn't have a CTEK sticker on it). Worth keeping an eye on the flyers for their next 'car week'.
ORIGINAL: RSGulp
The battery is usually fine, as long as I do not leave it for more than about 10 days and even then I can usually jump start it with out too much effort (apart from pushing the car up a fairly gradual incline), but it went completely flat as I left it for a good 2 weeks.
I guess a battery isolator switch would be a good idea, has anyone made this modification? Perhaps if I got a lockable one, it would double up as an anti-theft deterrant too, but the alarm would not function then [8|] It would be good for the periods when I am not driving though.
I will have a look in the local Lidl for the battery conditioner, hope it is still available. Will this take a battery from no charge to full charge as well as maintaining the charge over a period?
Colin,
If you fit a kill switch the battery will last for weeks. The immobiliser will prevent the car from being started when the battery is re-connected. You have an immobiliser right? - this is more than likely draining the battery. Buy the best CTEK conditioner you can afford - they can bring batteries back from the dead (almost!). If you have the facility to keep the conditioner plugged in during storage - all the better - you may not need a kill switch. HTH.
I'm not sure if a battery conditioner will re-charge a flat battery. I've just got a normal battery charger and that takes at least 24 hours to fully re-charge my battery. I bought a new Bosche Silver 7HN and kept the older one as a spare (stored fully charged) for times when the battery flattens. I too make sure I run my car at least once a week but have left it up to 3 weeks with no problems in starting.
For an intelligent isolator I use this one ....my car is a Tiptronic so there is no way to bump start it and I have never in 4years been left "battery stranded" as this box will isolate the car when it sees the volts get low due to draining.
http://www.noflatbatteries.com/index.htm
ebay via the US site is pretty cheap for these as well.
When my battery started getting tired I went to a local Battery centre,got one of those sealed maintenance free gel batteries that are now quite common in leisure boats.It is a much more environmentally friendly alternative.
I paid about £70 for it two years ago and its been perfect,it would also still start the car after a fortnight of standing in the garage.I then decided to fit another cigar socket under the dashboard that is permanently live.
I now keep the C2 plugged into a Porsche trickle charger and its been faultless since ,
Steve
hi i use this draper charger or rather an older version its pluged in all the time on my 993 !!
care
BM1(H)​
12V Battery Master
Designed to be left connected to automotive-type
batteries for extended periods of time. It will maintain the
battery in a charged ready-to-go state, ensuring, for
example, that a vehicle's alarm current does not drain
the battery. Fitted with crocodile clips, in-line fuse and
4M of cable. Display packed.
Specification:
Input ... 230V AC - 50Hz
Output ... 12V DC 300mA
Cable length ... 4M
Battery suitability ... 30 -140Ah
Stock Box Price
No. Qty each
63147
"" £25.66
5556
ORIGINAL: colin129
Yes it would fully charge a flat battery, it may take a week though! The math could be done to work it out.
i use a small solar panel. That keeps it charged. Only cost me £9.99.
I tend yo be OK. I bought a battery with a four year warranty. I seems to be lucky that it busts every two to three years and then get a free new one!
ORIGINAL: colin129
I'd recommend one of those portable jump start jobbies. I am sure they have a combined battery conditioner/ charger.
http://www.machinemart.co.uk/shop/product/details/jump-start-900/path/battery-chargers-engine-starters-2
Halfords ... five year guarantee and open Weekends and Holidays ... and a 964RS isolator ... just to keep it fresh ...[:)]
I ended up getting a conditioner from Halfrauds for £37. It took a good 36hours to bring the battery back 'from the dead', but it started the car straight off afterwards.
It also has a conditioner to maintain charge.
I will look at getting an isolator fitted at some stage.
My battery died after we went to the porsche picnic and my son flicked the interior light on. I have charged the battery up and use a solar panel to keep it topped up same as Pete917.
Waiting for her service to see if there is a drain on the battery or if it's the battery itself that's faulty.
Steve
