Battery
- Thread starter Guest
Steve Killoran
You evidently didn't notice he says there is no power in the garage!
Apart from Solar Cells on the roof I'm not sure what to recommend...
I've seen ones that plug into the cigar lighter exactly the same as the Porsche one.
Regards.
Steve Killoran
I have left mine at the airport for 3.5 weeks, and it started first time (well it turned over one or two more times than normal). It seems to last quite well.
Remember, for othesr reading this who are not aware, after 5 days the remote central locking sensor gets switched off, so pressing the key fob will not unlock the doors.
1. Can I use any old trickle charger or does it have to be a Porsche version?
2. More importantly...the battery on my 2003 C2 goes flat after 3-5 days. It's not the regular 5-day power shut-down, the battery actually drains flat. The first time it happened I took it to my OPC who put it on the ramp for three hours and told me the battery was indeed draining but there was nothing wrong with the car so it must be my Tracker. Tracker came straight away and replaced the entire unit and wiring, but after one weekend of no use, the battery was flat again. Any ideas?
(Looking back, when I originally collected the car (2nd hand) from the OPC it was parked in the showroom and they were charging up the battery. They said the salesman had taken it home the night before and left the radio on. I didn't want to wait so they put in a new battery on the spot and all was well, until...)
PGAdamopoulos
Batteries, unless they are used properly they last for 2-3 years problem free.
Tired batteries loose all their charge the moment a load is applied, and this can be tested at a battery shop.
Any trickle charger would do, but the most expensive ones not only charge, but also discharge the battery so keep it in form.
If there is no power available, disconnect the battery but first plug an Emergency Car Starter, e.g. http://www.autobarn.net/ec1300.html so you do not loose all of your settings.
By the way the alarm/immobiliser system goes to sleep after 60 hours and it responds only to a contact breaker, so you use the key to get in and when the alarm goes off you press the fob button.
See similar thread at http://www.porscheclubgbforum.com/tm.asp?m=126884&mpage=1&key=baterry🀿
One night around 01h00 in the morning I stopped for some petrol and when I went back the car it would not start.
Some very nice guys in a very old and battered Nissan were only to happy to start me up, but they could not help the green on their face and ask me "Isn't this a very expensive car". We looked like out of a cartoon... The next day I changed the battery....[]
ORIGINAL: jonathansbuk
How could they tell there was nothing wrong with the car? The porsche tester diagnostics said there wasn't? Not the same as actually measuring the current drain against the specs.
They said they had measured the rate at which the battery was draining and that this figure was higher then it should be. (Is that the right answer or the wrong one?!)
Open the driver's door with the key - as we used to do in times gone by, and then 'plip' the remote. Everything should then be fine as stated above.
I make sure that at least once every 4 weeks I take my current car (Boxster - 996 coming shortly), for a spin of at least 40 miles. Puts a big grin on my face, and the battery has never let me down on this basis.
[I am now touching a big piece of wood................].
I got 8 years from mine, others get 2.
If it's showing any signs of gailing then change it asap - or you'll find it fails completely just when you need it.[&:]
Use of a battery conditioner, and regular checking of the electrolyte levels in the cells helps to keep the battery in good condition for far longer.
Think an interior light that I hadnt turned off drained it when I had been cleaning it all day. Must have been on its way prior to that. Couldnt start it to get it in the garage and just kept making the clicking noise on turn over. Trickle charge all night didnt help. Had the embarassment of 3 neighbours helping me to push it back in the garage and the RAC out the following day to boost it [][]
New battery works like a treat. And found the old one hadnt been fitted to the tray properly and had been wedged in with a piece of wood ....
Craig
