silvermilnec
Can anyone tell me if the above unit can be used to easily replace the CDR32 unit??
Many thanks.
Many thanks.
ORIGINAL: Paul Fraser
Do you know if it does amber text on black background?
ORIGINAL: silvermilnec
Mark how do you find the unit? does the BT work well?
Only problem now is finding one! It seems Becker have been stopped retailing any HU with BT, somethink to do with Siemens and copy right! If anyone sees one for sale please let me know.
Thanks for all the advice, how did we ever cope without forums?
Cheers Chris.
Oy! .. I did! ... from my posting to you on 11th march this year (see http://www.porscheclubgbforum.com/tm.asp?m=358752&mpage=1&key=becker%2Cwire񗧭) ... I saidORIGINAL: silvermilnec
Perfect why didn't some one just say that!
ORIGINAL: Diesel130
I fitted one last year and it's a brilliant device. Look absolutely original in the car. Bluetooth works perfectly with my Motorola KRZR - no disconnections or anything, it just auto syncs up when you turn it on.
I had the CDR22 with optional amplifier and it was virtually plug and play, but I had to make a small change to switch the external amp on as the external power is on a different pin to the OEM box. Here's the detail if you need to do this ...
[blockquote]
Just wanted to add that I got my 7990 today, went to install it and no sound. It seems that if you have the factory fitted amp module (not Bose) it doesn't work out of the box as the signal from the unit on the CDR22/32 that switches the amp on is no longer on the 7990. It's been replaced by a sub driver.
So, thanks to some help from another forum here is the fix:
Cut the wire going to C1-6 (yellow block), leave about an inch spare in case you need to add in a sub. Splice this free wire into the pin 5 on block A ie A5.
You can get all this info in the back of the 7990 and CDR22/32 head unit manuals. [/blockquote]
Also see my other thread on fitting it .... "Access to A-pillar" http://www.porscheclubgbforum.com/tm.asp?m=297862
Got mine from sextons ... http://www.sextonsdirect.co.uk/GP7990_becker-grand-prix-7990-cdmp3wma-tuner.html
About 260 GBP with delivery.
HTH. ....
