Installed a traffic Pro a while ago and have experienced flat battery on regular basis since. Didn't put 2+2 together until doing some testing to locate source of current drain. Fuse D8(radio) drawing 0.3A . When disconnecting radio socket A current drain stops. Put the old Porsche cdr unit back in and everything is fine, no drain.
The odd thing about this being...Socket A on the back of the radio appears (according to the pin-outs on both units)to be pin for pin identical on both units. There is something mentioned in the Becker manual about excessive current drain if the wiring is not the same but the pin outs are identical? What am i missing? Other than draining the battery the Becker TP works fine. I am assuming something gets connected on the Becker that isn't on the Porsche CDR (apart from the Nav pins for speed and reverse). Any light shed on this greatly appreciated.
