beep beep
- Thread starter Billy192
ORIGINAL: ibaker
The double beep is showing that you have an error somewhere in the system. The car does a self test when armed and should remain silent unless there is a fault. /The only way of getting rid of the noise is either fix the fault or disconnect the alarm horn/siren.
^^^^^^ This.
If you get a diagnostic check done, it should show what the fault is. My money would be on a faulty microswitch within the door lock mechanism, as they commonly fail.
