stjohnsmythe
Just had the belts changed on my Lux. I know that it will need re-tensioning in 1000 miles but apart from that do I need to take it easy for a bit for the belts to bed-in, etc?
ORIGINAL: xenon
Rich's comment is correct - the tensioner does not dynamically adjust the tension, it's bolted in a fixed position once the tension is taken up. Which is a bit crap, but there you go.
ORIGINAL: geoff ives
Also, the sharp edges to the teeth wear slieghtly round. That is why a new belt whines but after a few thousand mailes it goes quiet.
