Belts too tight ?
- Thread starter ktel
RS2000CUSTOM
Mine whines and then goes quiet with only the slightest whine after a minute or 2
When I carried a lot of repairs including the belt changes I was initially worried and kept going back to the belt tension etc
At one stage I removed the guide wheel and the whine almost disappeared - the guide is the one that is not in constant contact with the belt and its as though it has to get up to speed to then go quiet
Hope this helps
So maybe there is a proper way to do it?
ORIGINAL: ktel
I had recently my belts done and now I think my engine whines a bit...
I 've posted a video with my engine sound. Is this whine normal?
Should I recheck tention ?
Thank you!
Video
pauljmcnulty
Need to check it after 1000 miles, so worth asking then.
George Elliott
The issues with an over-tight belt are the tension is applied to the rollers / water pump, cam shaft / balance shaft bearings, and causes wear, and it also sounds like a Zanussi on wash cycle.
Good reasons to get it right in my book
George
944t
pauljmcnulty
The correct tension is difficult to describe and can only really be guaged by feel
Or, there are two Porsche belt tensioners free to borrow for Club members... [
George Elliott
Paul, you'd be surprised how many different tensions they can produce depending on operator.......
I know I know, if used correctly [
George
944t
pauljmcnulty
ORIGINAL: Steviebear
How do we get access to these please Paul?
Call Club office. Paul Grainger normally deals with them, but anyone should be able to help.
You need to stick a deposit on a card, and I'd recommend registered post, but it's a great benefit.
I'd appreciate any ideas for tools we could buy in and use. Electronics seem to be deemed too fragile, but expensive specialist tools we can club together to buy, and then borrow?
blade7
Well-known member
ORIGINAL: pauljmcnulty
Or, there are two Porsche belt tensioners free to borrow for Club members... []
Or, you use the waterpump twist method that takes into account expansion of the block/head and doesn't knock out serviceable water pump bearings prematurely.
pauljmcnulty
Which doesn't sound at all technical to us non-experts! [
I use an indie, but if you want to DIY then the free (plus postage) loan of the gauge is there as an option.
blade7
Well-known member
Which doesn't sound at all technical to us non-experts! []
It's a while since I did it but from memory you set the cambelt tension using the auto tensioner and then back it off slightly so you can just turn the water pump pulley against the belt by hand, when the block/ head expand the belt gets tighter without loading the water pump bearing therefor extending it's life.
RS2000CUSTOM
IMHO it is the balance belt and pulleys in most cases that produce the whine
blade7
Well-known member
ORIGINAL: RS2000CUSTOM
Dont get too mixed up with cambelt tensions and balance belt tension
It's normal for a new balancer belt to whine slightly until up to temp, if the cambelt whines something is wrong.
George Elliott
DIY for me or a trusted indie.
George
944t
WXW611
