best oil ?
Good question - the normal answer would be to use a semi-synthetic oil, typically a 10w40, of good quality. The slight carbon break down you get with a semi-synthetic should aid sealing of the bores and the oil should stay in grade for a good 10K or 12 months, however your car sounds fairly highly tuned. If that's the case then you may be running much higher temperatures, in which case you risk breaking down a semi-synthetic prematurly in which case you may need a more specalist oil. Usually a fully synthetic wouldn't be recommended as it can run 'too clean' for the 'older' engines. You may wish to get advice from Esso/Shell/Mobil directly, however you could always ask what the teams used to run in 934/935 endurance racing?
