TISPKJ
Hi guys after Brands the little light tells me the pads are getting low ..........
Can you recommend something for fast road / track day use please, do they do a sintered pad ?
I found the ( I assume) std pads very soft / dusty although no problem with performance, thinking something with a little more bite and a bit more agressive, or is it best to stick with std fitment pads from porsche ?
Also noticed the drilled holes in the discs blocked up very easily, do they all do that with std pads or has someone fitted something softer do you think ?
