watlina
Many moons ago back in 2008 I looked at the prices of brakes https://www.porscheclubgb.com/forum/tm.aspx?m=392661 and did a sheet with a load of suppliers.
Well I don't use the car much (1600miles last year) and it's only just come round time to do them all again. I could probably get away with just pads on the back but I thought I might as well do the lot. Eurocarparts appear to be a good price with a couple of discount codes off the web. 10% "SERVICE10" covered everything but the damping plates and 5% "BOX-5" covered the plates
I thought it was interesting that prices haven't changed much in the intervening 8 years. Oddly the only things to really go up are the rear damping plates, they seem to be over double the prices they used to be.
I know I could get away with reusing them but I'll ring the OPC and get a new set of caliper bolts as well.
If anyone has anywhere cheaper let us know.
The detail from www.Eurocarparts.com
ECP Part No. Price Discount Price Part
104330528 1 £61.99 10% -£6.20 £55.79 Pagid Brake Disc (Front Right)
104330518 1 £61.99 10% -£6.20 £55.79 Pagid Brake Disc (Front Left)
104330538 2 £117.98 10% -£11.80 £106.18 Pagid Brake Disc (Rear)
101330488 1 £53.99 10% -£5.40 £48.59 Pagid Brake Pad (For Cars With Pin Type Wear Sensors) (Front)
101330178 1 £42.99 10% -£4.30 £38.69 Pagid Brake Pad (For Cars With Pin Type Wear Sensors) (Rear)
106330278 4 £39.96 10% -£4.00 £35.96 Pagid Wear Sensor (For Cars Using Pin Type Wear Sensors) (Front or Rear)
101339140 4 £31.16 5% -£1.56 £29.60 OE Quality Dampening Disc/Plate (Dampening Plate For Brake Pad, Qty 4 Required) (Front)
101339030 4 £27.16 5% -£1.36 £25.80 OE Quality Dampening Disc/Plate (Dampening Disc 28mm For Brake Pad, Qty 4 Required) (Rear)
101339040 4 £27.16 5% -£1.36 £25.80 OE Quality Dampening Disc/Plate (Dampening Disc 30mm For Brake Pad, Qty 4 Required) (Rear)
£464.38 -£42.16 £422.22
