Separate thread to get your attention.
3.2 about bog standard with 40 size webers and 2.4 dizzy, no electronics in sight ([&:])
I have the 40/2 litre inlets (mag alloy, bog standard) which have tiny ports compared to the cavernous 3.2 inlet tracts.
I spoke to Josh Sadler at the autoSport show by chance who thought these carbs on a 3.2 would be a great hillclimb engine, all torque if not power. Sounds good to me.
When I did my 2.4 E/S engine (2.4 E cams/2.4 S p&b and heads) with mech injection (what a great little engine that was) I ported the inlets to match the heads (not much to remove) but the difference here is FAR greater.
Question:
Should I do a serious porting job on these manifolds, '2 litre' to start at the carb and then blend open to match a 3.2 inlet gasket diameter?
Or: leave them alone and ignore the diameter difference?
Secondly: are there heat insulation spacers on the 3.2 engine? I think there are as the inlet studs are very long. I will need to use the smaller insulators from a 2.4 or similar as the 3.2's are notched to allow for the injectors.
Finally, anyone have any insutation spacers for an air cooled 911?!
Question:
