Reaching out to the community to see if anyone has had a similar experience to me and can offer suggestions.
Basically the PDK clutch appears to slip. The revs momentarily 'blip' when cruising accompanied by a metallic scrunching noise, every couple of seconds or so under load at lower RPM's. The same noise sometimes occurs when engaging gears. OPC has changed clutch pack fluid and re-synchronised the system; the actual change is much better, although still poor to mediocre.
OPC has asked Porsche technical department and basically gets told to follow the fault code guide, but the trouble is that there is no fault warning showing. Next step is to record and video the issue next week.
Any thoughts as to what steps I could take would be welcome. I cannot believe that I am the only person ever to have this issue, but within the Porsche network this does seem to be the case!
