ORIGINAL: clubsport
Having owned and driven both versions of the spoilers on the same track.....I would have to say there is a slight difference between the 2.
The larger spoiler kitted car, did feel a little more planted and stable at speeds above 100-110mph through sweeping turns as well as extra stability under high speed braking......then again, they were different cars on the same tyres, so that may be partly down to geo???
As far as Porsche are concerned.......
For the basic (small spoiler) version.
The modifications made to the body have reduced lift values almost to zero, at the same time maintaining the drag coefficient of the standard 993.
For the CS spoiler (larger) version.
The modified front spoiler, along with the fixed rear spoiler and adjustable rear wing, produces higher down force at lower drag values.
cd = drag coefficient
caf = front axle lift coefficient
car = rear axle coefficient
Fa = front axle lift (Newtons of force at 270 kmh 0r 168mph)
Ra = rear axle lift (Newtons of force at 270 kmh 0r 168mph)
N = newtons
Small spoiler kit
cd------caf------Fa lift /N------car------Ra lift /N-------Rear wing angle
0.33------0.03-------178---------0--------- 0------------------Fixed!
Large spoiler kit
cd------caf-------Fa lift /N-------car------Ra lift /N------Rear wing angle
0.34------0.00------0----------0.02--------
negative 119------0 degrees
0.34------0.01------59---------0.05--------
negative 297------3 degrees
0.35------0.02------119--------0.09--------
negative 535------6 degrees
0.36------0.03------178--------0.12--------
negative 713------9 degrees
Above data from Porsche, you can see that adjusting the angle on the larger rear wing will give "negative" lift or down force at the back end.
As the drag coefficient rises, you would also expect a car with a CS spoiler kit in full down force mode to have a lower top speed.
Porsche have obviously designed the spoiler kit for a reason, but at the end of the day it's academic as well all know that the small spoiler kit is far more aesthetically pleasing than the vulgar CS kit! [
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
*Apologies for formatting of above data, I had to try to fill in the gaps to make it legible.
