Diver944
You may remember that my turbocharger finally wore its oil seals out last month and started smoking badly. I took it down to Jon Mitchell in Bournemouth to fit a new Lindsey Super 61 Turbocharger and a new headgasket at the same time as I was preparing to start running at 18psi boost and my headgasket was still original after 16 years and 120k miles.
Now that the head is off it turns out that I do have some scoring on cylinder number 1 (probably caused by the fine metallic dust found on the piston rings which has come from the turbo impeller or maybe a loose bolt in the airbox)
The options are a 2nd hand engine or a rebore. I have never liked the idea of a 2nd hand engine especially as its an unknown quantity so we are proceeding down the rebore route using Perfect Bore who know the 944 engine, its coatings and are trusted by Jon. This will give me a number of options:
1. Line the cylinders, bore out to standard size, coat and fit original pistons
2. Bore out to the first oversize, coat and fit oversized pistons
3. Bore out, coat and fit 2.8 pistons [
Option 1 is obviously the most economical and currently my favourite. Options 2 and 3 will be a similar price as they both require new pistons. 2 & 3 may be forced upon me if the liner route is not possible, in which case I would choose option 3 because there seems little point in taking the whole thing apart and having new pistons fitted which are still 2.5
Man I miss my car, I'm bored with the Turbo in my van already [
