I guess first of all the more cost effective option is to go for some higher boiling temp fluid like ATE Super Blue or even Castrol SRF. Also adding some brake ducting would help. Maybe take a look at the 968 cooling duct arrangemet - you may be able to fit that onto your car and the parts are not that expensive. Not sure if the calipers off a 944 S2/early turbo would work with your disks - would need some brackets fabricating, but that should be fairly easy if you have access to a machine shop or know someone who has.
If you have 17 or 18" rims and assuming that the 924 offset is the same as the early 944 offset then there is a chap in Norway that has fabricated a brackt kit for Medium Blacks (as fitted to later 944 turbo's), big blacks/reds (as fitted to 928GTS and 964 and 993TT's) and the more modern brakes off 996 turbos/GT3 mk1's. The disk for these callipers are tricky due to the offset but he's also developed a disk hub for floating disk rotors that work with the early offset 944's. Complete and utter overkill I know, but when it comes to brakes a bit of overkill is preferable to underkill, and they look very very nice. But very very expensive!!
