Bilsein B6 - free to a good home
clyde
I have just had my suspension sorted out at Center Gravity and as part of the pre-set up checks one of the rear shocks was found to be knackered, however the other one is fine. Bilstein can rebuild the unit for a charge of £90 if nothing else is needing done and provide their usual one year warranty for re-built units. As I had travelled around 300 miles to have my geometry done I couldn't hang around to have them re-built so Chris put two new ones on and I left the old ones at Center Gravity.
The good one has only covered around 15 k and tested well but the bad one is well bu99ered and will have to be re-built. To get a matched pair it would make sense to have both re-built but if you've got a failing one and are on a budget "¦
If these are of use to anyone, either as they are or re-built give Chris a ring on 01827 718800 and he will sort out collection or fitting (obviously for a charge).
And yes, I can thoroughly recommend Centre Gravity, Chris and Pete transformed my car.
