Binding brakes?
- Thread starter mikfinch
Jon
However, it is always best if the brakes are hot and dry when the car is parked as the discs are prone to corrosion on the inside. There should be something in the handbook about drying the discs after cleaning.
I say this because it has never happened to me, even when garaged wet and left for days................until last week. Now I have exactly this problem after leaving the car for 24 hours, even when garaged dry. Bit of a bang as the front brakes release themselves, followed by the sound of binding for the first hundred yards. Then all is well again.
carrera4boy
Ex Club Member
I don't think this is a major problem though.
Si
John Ware
Normally at the airport they are OK, not sure why it is not so bad - maybe just lucky.
In the summer it can also happen if there is a thunderstorm and water splashes onto the discs.
As long as you drive it regularly, then it is not really a problem. A couple of good hard brakes from speed will clean them off.
The only way to stop it would be to coat them with something, e.g. WD40 or oil, which might be OK if you are laying the car up to the winter, but when you come to use it again you will have no braking at all to start with. Not sure how you would clean them up again.
I just take it as a sign that I am supposed to use it every day.
It does NOT make them slippery as WD40 would !
A bit expensive if you use every day (it is £5 a can) but I have used it if washing the car and I will not be able to take for a dry after. 38K miles on the original discs so far - including a few trackdays...[
How come?
JohnC
993turbo
ORIGINAL: Stuart Martin
This is probably because the car has been parked after a longish drive when the brakes are hot and dry, then left in a well ventilated area.
The worst thing anyone can do is to wash the car and then garage it. Water sits in the holes in the discs and dribbles down the back creating the perfect environment for rust. Eventually the pads won't remove this and the discs will need to be skimmed or replaced.
Also when I drive home they are hot, but yet are also sticking by the following morning.
In both cases they are warm and dry when I stop, and in both cases the car is outside.
It depends on the weather conditions I think - how humid it is and whether it gets cold enough for the water in the air to condense on the discs. Why the airport carpark is better, I'm not sure. Possibly the area is slightly warmer and less prone to mist/fog, but more likely I have just been a bit more lucky with the weather.
hothatch2002
We have recently had some very changable temperatures - very cold and then unusually warm, and so on. What happens during a prolonged cold spell is a drop in temperature of the garage and the car - which can take some time. Then the temperature outside increases again, but your garage and car are now several degrees below the current outside temperature and the result is water condensating on the cold surfaces of your car and garage. The only way to stop this is to have ( as I do ) an integral garage to your house, so the temperature inside the garage is always warmer than outside. I store my car for most of the winter and never have any problems.
If you store your car outdoors, then it will possibly happen every time is rains. I'm afraid that Porsches just don't like being left out for a period of time.
Michael996
I do worry what stresses it puts on the drive train of my car but what can we do? is it possible the calipers are not returning home fully when we all park up? just a vague thought.[8|]
dereksharpuk
ORIGINAL: Michael996
I am having the same problem with my 996 even when parked in a heated garage, what I do find odd is my Jag and my Range Rover do NOT have this problem.
I have this problem on both my Caymans and now on the 997 Gen 2. I have no problem with the Mini Cooper driven in exactly the same way, eventhough I dry the Porsche before I put it away and don't bother with the Mini Cooper. Given the significant problems I have been having with brake squeal (see 997 Forum), I am less than impressed with Porsche brakes.
dereksharpuk
Michael996
I have tried everything to stop it I think it has something to do with the size of the pad and the fact there drilled
My Jag has EBC grooved and spotted she is parked up outside and never has a problem
[8|]
