day1zero
Any ideas?
Symptons
1. Engine off - Will engage any gear relatively smoothly
2. Engine on - Will no engage any gear at all.
3. Engine/Gearbox warmed through (15-20mins) gears started to engage in order 6-5-4-3-2-1 R (Bizarre)
4. Once warm gear engage relative smoothly with no issues.
I have replaced the Gearbox Oil - with recommend from forum from Opie Oils. Gear change appeared smoother, however, still same snags.
Suspect clutch? however, had new clutch approx 15k ago any suggestions?
TVM
Symptons
TVM
