Bleedin` clutch
- Thread starter Hilux
Hilux
Just read it.
You have to remove the starter to bleed the clutch????????[&:]
`kin `ell, methinks I cant be arsed and I`ll book it in somewhere but not until I`ve tried bleeding it by cracking the flex to metal pipe joint at its highest point. [] It shouldnt get air running down the pipe to the slave cylinder as that should stay full particularly if you reconnect the flex and fill the master cylinder end. Any air then `should` be driven up to the highest point and exited via that union.
Ho hum......................
