Monkeythree
Is there a trick to getting S2 Brembos to bleed properly? I've been at mine for ages and struggling to get any meaningful amount of fluid through the rears. Have had an assistant pumping the brake pedal for 40 minutes this morning and I've switched to a vacuum pump this afternoon because i was working single handed. Not having much joy with either method really. The front right is pulling through clean, the front left is still pretty frothy and the rears are 90% air with the odd splutter of fluid here and there.
The system was completely empty when I started because I've changed several lines and all the hoses.
Any suggestions?
Any suggestions?
