Advice needed please.
Car: 1993 RS Lightweight LHD.
I needed to replace the brake fluid as the brake pedal was going to the floor at the track and the diagnosis was that the brake fluid had boiled and needed replacement. I do not know when it was last changed. The existing fluid is 'normal' brake fluid colour.
I bought a Gunsons Eezibleed kit and 2L of ATE Super blue fluid. Following their instructions I:
Clamped the brake fluid reservoir vent tube at the flexible section. Connected the Eezibleed to the tyre at 20psi. I drained all 4 corners under pressure (is this where I went wrong?) in the order: Right Rear, Left Rear, Right Front, Left Front.
Filled the Eezibleed canister with ATE brake fluid. Re-pressurised the tyre and bled the brakes in the order: Right Rear, Left Rear, Right Front, Left Front until old brake fluid and then blue brake fluid came through and no air bubbles - didn't take long.
Problem: the brake pedal goes straight to the floor and there is little or no braking effort. If I pump the pedal: the effort builds up (I can hear the pump whirring) - then the pedal goes solid after about 5 cycles but only for a second and then the pump (or a pressure relief valve perhaps) starts whirring, the brake warning light illuminates and the warning buzzer beeps about 5 times. I take my foot off the pedal and after a few seconds try again but the brake pedal goes straight to the floor. Brake fluid is also pouring out through the ventilation tube onto the road during all this activity. If I go round to the front the pump is running and running and then eventually stops.
Help!
By clamping the flexible pipe have I starved the pump of fluid? Do I need to bleed the pump too? Where have I gone wrong and what do I need to do?
Help!
