Hi All,
OK I built a blink code tester to try and read any codes that maybe stored in the DME. I followed the instructions at
http://www.pff.de/linked_stuff/PorscheDiagnoseSchaltplan.pdf
after using google to tranlate it, but the circuit diagram is easy enough to follow.
My problem is that document refers to a round 19 pin connector, however my S2 is of an 89 vintage and so it only has the rectangular 12 pin connector. I looked through the manuals and can't find a cross reference to say exacly what pins I should use.
The only info I can find is in the main engine manual page 03-3 and 4 which shows the 12 pins however on one page it states using pins 1,2,5,9 and on the next it says pin 9 is unused, plus this all relates to the 944S and not 944 S2. Futher down in the same manual it shows the S2 pages 24-28 and even mentions the 12 rectangular connector but no reference to what pins to use.
So the big question; Does anybody have any idea what pins on the 12 pin diagnostic relate to what pins on the 19 pin diagnostic socket
All help much appriciated
Gary
Gary
