Blocked drain tubes
- Thread starter Tan
You need something stiff but flexible to do it - make sure it's not going to tear a hole in the tube that needs cleaning though.[&:]
Black80XSA
Don't forget there is one under the battery as well !
BartyB
For aspiring gynaecologists, to get access to the tubes at the front you'll need to remove the plastic battery cover and, at the rear, partially lower the hood. It takes about 5 minutes to do all four tubes.
