Retrobuggy
Why is it when ever theres a problem, right at the bottom of it is a bloody cowboy bodging things up, I finally got the bodged oil pipes off just to find the idiot who put the pipe in only messed the thread up on the thermostat outlet, so what did he do? he run a tap though the inside off the pipe on the thermostat, so now I have to replace the stat, unless I can get a fitting ( male each end) which matches the new thread in the state outlet and the oil pipe, as it is I have to re-weld the old scavange pipe from the block as the idiot chopped the end off and put a leaky compression joint in so it would match the 2ft long crappy flexy pipe, I cant fit the new one I bought because I cant undo it at the block end. Why dont people just do things right, add this to the fact im having to re-do work at my girlfriend place because of cowboy construction firms, sorry to rant but it really winds me up. Any suggestions or does anyone have a spare thermostat forsale, cheers all. Sorry again
Here is the dodgy compression joint, which has to be cut off and the original elbow welded back on in situ
Here is the lousy Flexy pipe.
Here is the messed up stat, notice the stripped thread and the new thread inside.
