Blower Woes
RICH7105
Hi
Got in the cab for a spin with the roof down today and feeling a bit chilly put the blower on - it only worked on speed 4 ! Speeds 1 - 3 were kaput ! Is this a common issue ?? How do I solve it (so I can fix it when I finally thaw out).
Rich
Happens to me now and then too, but always rights itself.... possibly a linkage problem... to be honest I'm sure I knew why this happens in the past but I can't remember for the life of me now....lol
not much help.. sorry[:-]
Pete
Pretty common mate sounds like your blower motor resistor. Different resistors limit the voltage to the motor and hence alter the speed. Never had it on mt 944 but the setup is much the same for most cars.
At the back of the engine bay, just to the left of the fusebox and under the flimsy plastic cover is a 6 inch long block. The wiring inside it breaks down so that eventually it only runs at speed 4 all the time. Porschapart sold me a S/H one for a tenner a few years ago, it simply unplugs to replace (I even think it has the part number stamped into it)
As Paul said, it's the resistor that fails. You should be able to take it out, and spray some contact cleaner over the microswitches if you're lucky.
I was going to start a similar thread as I have exactly the same issue, occasionally I get 1-3 back but then they go again
Thanks chaps!
Followed the advice on here and fixed my heater blower, thanks chaps!!![:D]
Just one top tip: Do not, under any circumstances, use WD40 to clean the resistors......[:'(]
I did and when I was sat there with the ignition on to fix my mirror links, the car filled with acrid smoke.....I put the blower on full to try and clear it and then left it overnight to dry out. It was still a bit smokey this morning, but seemed to be better tonight!
