Pieman7
in my post what did you do I have explained I'm changing the oil leve/ temp sensor when I open the box they sent wrong one so put the back together and started her. She started but made a blowing air noise and ran unevenl. Checked that all hoses were back on propearly etc and found nothing it seems that something has even sprung a slit in a air pipe or would it do this if the flexible part of the oil filler pipe had a split somewhere. I must mention that I did close the boot lid with the battery disconnected ( you plonker Rodney) I thought but I remembered the red tag that pulls out of the fuse board so I connected my jump battery pos to the red tag and my neg to the door latch and it worked by the key again great little design.
