Mckay
I was having a quick look through the search engine to see if anyone had added bluetooth connections to their PCM. I have found an advert for a company on piston heads who have a system which links with the PCM but via bluetooth and you can make phone calls via the PCM with all details on the screen. Anyone come across this system? It says in the add that they remove the porsche phone module and replace with this bluetooth connection.
I have a 52 plate C4S with PCM but i'm not sure if its series 1 or 2 (i think it's 2) but on the website it only shows the new PCM fitted in 997 etc so don't know if its compatable or how much (no price on advert which isn't usually a good sign.)
It would be good to use the phone function on the car as it would appear that the sim card slot is welded shut, therefore whoever spec'd the car took PCM but not phone package so if there was a module i could add it woul be great. I personally don't really see the point for the small addition it adds on such an expensive car but never the less its either this or back to a parrot system.
Any advice or knowledge on this subject would be appreciatted.
Mckay
Mckay
