Body clay usage?
- Thread starter cococola
Neil Haughey
cococola
ORIGINAL: Neil Haughey
I can't see much wrong with claying every few months. Depends on how long the wax lasts. I am using Meguirs Tech Wax at the mo and to be honest I don't think it lasts more then 2 months at the most. Therefore some amount of polishing and or clay bar action would be required maybe 3 times a year or more. I would imagine that given what each does it would be more acceptable to clay on a regular basis then polishing. If one assumes that by polishing we are reffering to paint correction, rather then given the car a quick once over with something like Autoglymn super resin polish.
cococola
ORIGINAL: mik_ok
I would clay it ~ since waxing after claying only takes 38seconds anyway.
Diver944
Once you have clayed a panel it 'should' not need to be done again if you keep the panel waxed properly. Regular waxing will stop deposits sticking to the paint. A good test is to put your hand in a plastic bag then feel the paintwork. If it needs claying you will feel all the deposits through the bag. A nice smooth surface will have the bag gliding across and you know you will not need to clay.
Hilux
Clay should only be used to remove deposit and detritus that have adhered to the paintwork. Once you have clayed a panel it 'should' not need to be done again if you keep the panel waxed properly.
Brilliant......I`m off to get my shovel, we have loads of clay in the field next door.................................
cococola
ORIGINAL: Diver944
cococola
ORIGINAL: skendrick
Is clay better than stage one, I use the three stages and never used the clay bar, what's better?
berg944
What must your neighbours think[
Mike[:'(]
Wash car with fairy liquid using two buckets
Clay car, everywhere including windows door shuts etc. This removes microscopic detritus which won't be removed by polishing or you would rather not grind into you paintwork if it works loose.
Sonus 1 to remove swirls and oxidation using PC with whatever colour foam pad required.I forget now
Sonus 3 to polish to mirror finish using another foam pad using PC. can't remeber which one either
1x Coat of Rejex polymer sealant. (everything, windows tyres, the lot) by hand. Allow to set. 12hrs I think
2x Coats of Concours Swissol leaving to set as directed. Applly thinly with PC and foam pad.
Buff with buffing pad and PC. and a light spray of water
Wash car only with water or the correct shampoo there after. I only washed the car twice in the last year, and it lives outside in London.
All the above using a PC. By hand it is impossible. trust me I tried for years. Use a rotary polisher at your peril unless you are well experienced. You can burn the paint or polish right throught it in a matter of seconds. Halfrauds polishers and the like: absolutely 2000% more useless than walking up an ice hill on roller skates.
Not cheap, but ten hours a year well spent. I have better things to do than waste time with off the shelf crap 6-12 times a year.
This is not an advert. I don't sell this stuff, know anyone who does, nor do this for a living. It works on my paintwork but may not be suitable for everyones.
Erm, take care washing with Fairy Liquid as it contains a lot of salt and WILL make your car rust.ORIGINAL: Mikie_gb
Try a shampoo - any car shampoo - as it won't have this effect.
The idea is to strip existing wax off not preserve it with specially formulated car shampoo. After it is waxed is another story.
