bonnet struts
davepaul993
hi my bonnet is starting to droop,
so i need some struts can you advise where best place to get them from please,
There are several threads on here with lots of tips - try this one first.
http://www.porscheclubgbforum.com/fb.asp?m=535336&key=
ive just finished my drivers side one !
it was a bit awkward releasing the old one,
i think the worst bit, no not dropping clips or pins !
but putting the cover back on the pollen filter.
so just doing the one has made a big difference,
one to go now !
as to doing it for the 1st time you have to test the clip a few times to check it releases,
then once alls clear`er to try n see what your doing, it is a lot restricted on viewing
then once its done you wonder why you thought it be worse than you thought.
it went fairly smoothly, just got the easy one to do
at a latter date now !!!!!
cheeRS
ps i got heavy duty ones from type 911 all in for £24.00 see below !
http://www.type911shop.co.uk/shop/category_633/Bonnet-_-Lid-Shocks.html?shop_param=cid%3D%26
