Boost Enhancer
- Thread starter skendrick
berg944
I have just removed mine due to fitting a Promax Level 2 kit yesterday.
Hope its now quicker than mine now........after spending all that money[]
Mike[:'(]
sawood12
Berg - are you not satisfied with your Level 2 kit? I completed the level 2 kit install a few months ago and apart from a 5mpg drop in fuel consumption i'm pretty happy with it, although it's just wet my appetite for taking things to the next step!
Diver944
ORIGINAL: Lemon
See you Tuesday after a few G Tech runs.
Lee
I'd be interested to see what the G-tech records. Did you do any measurements before the upgrades?
berg944
I don't have one!
I am not sure what I have but lemon can confirm it's got a bit more than a standard 250 bhp and less turbo lag.
It is 80 kg lighter than a standard (none sun roof) car, weighed on the same scales (approx. the same amount of fuel)
I have not looked at chips but it still has standard over boost protection.
Car was built for promotion of a track car company in 1990, I have been told that it was 460 bhp (but before anyone kicks off, I don't believe this either). It is possible that it lost a few bits to tone it down for the road, there could possibly be different engine internals, but it's all guessing and I don't intend to look at the pistons (unless they are poking out of the block).
I have definitely got a racing clutch after trying a standard one.
Mike[:'(]
Lemon
Had just over 200/205 recorded on Mike's G Tech, although later runs did show two runs at 251???
Now with DPW, uprated fuel regulator, chip and Bailey DV, will give it a whirl this evening.
Will let you know how it goes.
berg944
IIRC the G-Tech gives a figure for power at the wheels so 251 would be about right for mild modifications (circa 290 flywheel bhp).
What would a standard turbo read at the back wheel?
Does this mean the 220 & 250 standard car is measured at the flywheel?
Mike[:'(]
