Grant
Interesting!!!
Had a new spec. alternator on my 996TT & asked the OPC to check/re-set the ECU boost pressure at the same time (disconnecting the battery for a few mins re-sets the ECU, don't try this without chatting about it first!), as the adaptive ECU's have an aggravating habit of giving a softer boost over time if you do a daily commute that doesn't stretch the car.
I don't know what they did, but since it has returned the car is simply flying, it is like a different car & now produces 0.9 bar boost (1.9 including atmospheric pressure) at the red line. It is a standard car (with cargraphic sports exhaust) without X-50 & should produce 0.8 bar at around 2700rpm dropping to 0.65 at around 6,000rpm!
The reason for the post is to ask fellow 996TTers (standard & X-50) exactly what boost they are getting, maximum & at the red-line?
