Boot Lid Badge
- Thread starter Guest
juliany27
The cost of the badge is something I do not know, but I would advise that you very carefully clean and prepare the area and make sure that there is no glue etc. before afixing a new badge. In my case a liberal use of very hot water to remove all traces of teh glue worked wonders.
Somewhere on the Boxster forum is the sad tale of my lack of technical skill and also very good suggestions as to how to do it correctly. Otherwise ask more questions on this forum; soemone somewhere will have had the same experience.
If this makes you feel better, the Porsche centres on the wheels are also popular - and the police are fed up with having to deal with complaints of theft/criminal damage.
Edited entry - I have just found the Boxster forum dealing with my 'adventures' - it can be found at http://www.porscheclubgbforum.com/tm.asp?m=198738&mpage=1&key=water𰨹 Hope this helps.
The front badge has no fiddly glue to remove like the 'Boxster' script...it's just a plastic gasket and the badge itself, so should be a lot easier to replace.
Good luck.
Keggers
http://www.porscheshop.co.uk/acatalog/porsche_boxster_badges_decals.html#a3810
