boot lock works at last
cococola
My boot barrel has never worked from the key on my 944 and due to the unreliability of the interior release button I purchased a new barrel off ebay for a tenner.The chap who I bought the barrel from was very helpful as he changed the barrel tumblers to match my own key.I fitted the barrel today and all works great.
It just goes to show how repairing the smallest niggles can be satisfying[:)]
NOOOOOO !
I have a 968 CS and its the one bit about the car I hate [:mad:] It would be fine if we drove on the opposite side of the road, but every time I need the boot I have to walk over to the passengers side, open the door and pull the cord.....
... Then walk to the back and discover its not fully opened & repeat. [:'(]
I can imagine its a pain but luckily for me the cars main duty is going to be on the track so i doubt i will be filling the boot with asda carrier bags to often !!!
I have one in mine, but I ran it to the driver's side as Porsche's laziness with the 968 CS was ridiculous.
For those who are less worried about weight, most aftermarket alarms have additional 'channels' which allow you to remotely control other car functions. I interfaced one such channel on my alarm to the boot release, which now means you can open the boot from the remote control fob.
Not hard, and quite convenient. Why more people don't do it I don't know.
ORIGINAL: Fen
Fen did you buy all the parts from an opc if so how much did they cost ??
I have to admit I just removed the motor and left the key lock which suits me perfectly. The lock mechanism doesn't weigh much at all and given how often I pull the carpets up I reckon its safest that way for me as I bet I'd keep snagging the pull cable. My spoiler does make it a little tricky to get the key in however.
I used a pushbike brake cable from Halfords. I actuaally on half finished the job to be honest.
Newer cars don't operate from the key at all, Peter. It's just another way of triggering the motor.
ORIGINAL: Fen
[:)] Thanks Fen
I have a feeling we discussed this once before which makes it even more embarrassing. I have a memory like a goldfish, but at least that way every day is filled with loads of new discoveries [:D]
My indie reckoned the early 924's used a mechanical system operated from the boot key only, no motors etc and hence less to go wrong. I was toying with changing mine but got the part I needed from a breaker for £10 as opposed to the £100 Porsche wanted. Also you'd need a spare ignition key for occasions when you wanted to keep the engine running.
i have the option to add the electic release from my remote but didnt know where to get at the wires behind the lecky switch, thought i may break it trying to remove, should i run the wire right to the rear and wire it at the motor? Could i be cheeky enough to ask which colour it is[:)], spent quite some time figuring out the central locking and getting the hazards to flash so havent got round to the boot!!
cheers JB
'88 s
If I remember correctly, the boot lock is triggered by making a connection to live, which starts the boot release motor turning. Once the motor is turning, the mechanism in the boot maintains the contact via a built-in sliding switch to keep itself connected to live until it has completed a full rotation - by which time it has un-latched the boot, and it then comes to a halt. The switch in the drivers footwell makes the brief connection to live to start the process, so you need some system that will briefly produce 12v, mimicing the operation of the switch.
If you take the switch in the footwell out (I think you need to pull the carpet away to do this - carefully!) you will see how it works, although I also used the wiring diagram from Rick Cannell's site to fully understand it. I'd love to tell you the colour, but I can't remember! However, it is easy to decipher from the diagrams.
I seem to recall that my alarm would only make connections to earth (i.e. ground out a trigger wire), so I had to use a relay to interface between the alarm and the switch. I recall mounting the relays (I used a couple for other things as well) in the passenger footwell on a small plinth which I made, connected the alarm control box to the relay in question and ran the control wire from the relay across behind the dash to the drivers side where it splices into the boot release switch wiring.
As with all these things, the electrics are simple. The time consuming bits are understanding the existing situation, dismantling the car to get at the relevant bits and making the end result look like something other than a terrorist attack in a spaghetti factory. (I am more than a little sad when it comes to tidy wiring!)
Cheers Oli!! My system comes with optional + or - output for boot release so im lucky. Thank the lord as i had enough of relays when wiring up the hazards. thanks for the info
JB
oh anyone fitted springs in the mechanisms so the boot pops straight up at the push of a button? thats my aim
Would new struts make much difference to the boot popping up when opening as sometimes on my 944 I have to attempt release control 2/3 times before I get it released?[8|]
