Rossy1234
Hi guys, having abit of a mare with my boot at the moment, it kept flying open when i went over speed humps, so i got new pins and new catches from the opc thinking this would solve it. Having fitted them,with the pins too short it won't catch and any longer it catches but won't open!! The only way to open it is with more force then i'd like to use!
Looking down at the catches when the boots open, the catches are releasing fine when the button is pushed and with the key and the pins appear to be going into the centre of the catches from what i can see when shutting it.
When you shut it, its locked in fine, if i do the key it seems to be releasing it a little bit but not enough so needs force to be opened. The only thing i havent replaced are the struts, could it be that the struts arent lifting the boot enough when the catches are released or is it something else?! I'm sooo confused!! [
Cheers Ross
Cheers Ross
