Bosch tune up?
PaulHere
If my 1983 car has a Bosch CIS fuel injection system does it follow that I should take it to a Bosch Service centre?Now it is back on the road with the new exhaust the car is idling too low and cutting out, so I would imagine it needs a tuneup.
Thoughts?
It isn't rocket science, doing it yourself isn't difficult. The problem you will find is that most modern mechanics don't understand it and will keep replacing items in the hope it will fix it and it will prove expensive.
If you can find a garage that is used to the CIS system, used in old Mercs and Fords also, this will be to your advantage.
Resolving these issues is just a question of doing basic checks, a fuel pressure test kit is first requirement, and being methodical.
scm924s is correct. Most garages will get totally confused when they can’t plug a diagnostic kit into your car so finding somewhere that understands k-jet will help in the long run (VW specialist would also be an option as mk1 & mk2 golfs used k-jet). If you're handy with a spanner the systems not complicated to work on and with a fuel pressure gauge made up you can check the pressures then find a friendly garage to check emissions.
Maybe phone round some local garages and ask if they still have the knowledge of k-jet systems and go from there.
Paul,
if it was working OK when you last ran it ,then K-Jetronic should still be correctly adjusted now but perhaps something has been altered slightly.
Has it got the original fuel in the tank?If so,the benzene content may have settled out.
If the fuel pump is running ,it's a good idea to check it's current draw-anything over 8 amps indicates deteriorating performance & pressure levels are critical in the CIS system,hence the suggestions above ,but if there have been no changes made ,it might just need the mixture checking which requires a simple exhaust gas analyser ( such as the one Gunsen do) & an Allen key.
Possibly RPM Technik in Hertfordshire could look at it for you-although I have not used them,I have been there when my son bought a 964 off them & they appeared to have 924/924S/944 ability.
Totally agree with scm924s.
GT one at Chertsey do understand the system, they worked on mine after some repairs. Tuned it and sorted the hot start.
Many thanks for your tips, I'm sure it needs looking at as the fuel pump, the fuel lines, the flux capacitor, and, oh yes, the spiders nest from the air inlet have been replaced or re-homed.
As an aside, is is possible to increase the idle speed alone without upsetting any other settings?
You can, but ideally should be adjusted in conjunction with the mixture control. The idle adjust is on the throttle body below the throttle lever, facing you. 1/4 turn anti clock should be more than enough.
