Boxster 981 vehicle tracking system
Ronald Racher
The vts on my 2014 981 boxster no longer works immobilising the car so it wont start and a Porsche dealer has advised it will cost me £1151 to replace it with a new vts!
The only possible option is to install a piece of software from Porsche to workaround the vts so that it's still possible to start the engine & go. This workaround is of course vastly cheaper but my nearest Porsche centre are saying that this cannot be done on 2014 model years - even though it can on earlier & later years (not 718 series) yet - it is the same vts fitted to all 981 years.
Please note that my independent porsche specialist disbelievers what the dealer has told me and is investigating further.
Has anyone come across this? Please advise/relate your experience.
Thanks -
Hi Ronald
l’ m sorry to hear of your difficulties with your vts especially as it sounds as if it wont let you drive the car.
l don’t have much experience of the system other than this system wasn’t working on my 2015 gts, although perfectly drivable, when l bought it last August from an OPC .
After much too-ing and fro-ing to the dealership and Vodaphone Automotive, who operate the Porsche system, Porsche had to replace the whole system, thankfully under warranty.
Vodaphone were quite helpful at the time to help resolve this so l’m suggesting a phone call to them may at least get the car identified on the system and released to drive , if not fully protected.
Their phone number is 0333 122 2222.
Les
RR
Not sure if this helps .I have a 2013 981 PDK 2.7 Boxster ,last month went to start it fired up then immediately died would not turn over ,got RAC out to try and start it nothing ,but showed a VTS code .I never knew my car had this found a fob that I was given with the car 3yrs earlier but have never contributed to any tracker subscription. Car was trailered to a local indy who investigated found initially battery was dead 10yr old not holding charge and fitted new one still nothing then found the Siren module was faulty part no PAB951605 £233.I believe any VAG module will fit and possibly cheaper ,well car started and has been ok since ..
