Hi I have a Boxster 981, and the windscreen washer pipe is a black ribbed pipe, which runs from the windscreen washer unit through the bonnet and finally connects to the windscreen washers. This pipe has broken where it enters the bonnet and where it is attached to a black plastic panel that holds it in place. I have no working windscreen washers currently. Can anyone advise what replacement pipe I need for this repair and how do I access and fit it to the washer bottle and through the bonnet to get the windscreen washers working again. Many Thanks
Boxster 981 Windscreen Washer Pipe Broken
- Thread starter neil.wilkie
There are several threads on other forums about this revealed by Googling, one of which is here https://rennlist.com/forums/gt4-spy...washer-fluid-tube-break-fix-one-solution.html
Very common this brittle ribbed pipe breaking it was replaced under warranty.
