At the start ,I would like to say hello to everyone. I am new on Porsche Club. My name is Marek, I live in Watton, Norfolk. Back in January, I bought my first ever Porsche, which is Boxster 986 2,5 1999, and I love it but......
About 2 weeks since I bought it, engine malfunction light appears on the dash, and engine starts running rough on idle.
I plug the car in to my diagnostic tool(its Launch X431 which, over 10 years diagnose a lot of cars with it). Faults :
After reading various posts looking on forums and YT I ve decided to remove bank 1 camshaft cover and check Variocam chain guides, and found out they were badly worn so I went to Porsche Norwich and bought 2 sets for each bank. I ve replaced them. After repair engine was running smooth, no fault codes.
Around 30 miles after work engine light come back on. This time with diffirent faults:
I decided then to delete all faults, keep driving until light will come back on, and check if same codes appear. After around 3 days and 60 miles light come back but with diffrient faults(same as first time, before variocam cam guides repair) !!Engine was shaking on idle:
Live data stream
I ve deleted all codes and done live data stresm and deviation was still 25° crk!! I read somwhere that 10° is equivalent to 1 tooth out. not sure wether thats true or not.
Today I ve checked timing on bank 1 and it is as it should. Crankshaft on TDC and exhaust camshaft on bank 1 as it should , tool installed.
When I was replacing vario cam guides and realigning timing Ive notice that exhaust camshaft sprocket on bank 2 was roughly in the middle of its adjustement but on bank 1 ex camshaft sprocket was near the end of its adjustement. After variocam guide repair and realigning timing,ex camshaft sprocket was in the same place. not sure if its normal or not, in my opinion both ex camshafts sprockets on bank 1 and 2 should be roughly in the middle of its adjustement.
At the moment I can see few things that can be wrong:
Just wondering if someone had similar problem and could advise? I would be very, very, very greatful .
Best Regards
Marek Rybak
- 174 Camshaft adjustement bank 1
- 322 toothed belt out of position bank 1
- 62 misfire emissions-relevant
- 50 cyl 1 misfire emissions relevant
- 51 cyl 2 misfire emissions relevant
- 52 cyl 3 misfire emissions relevant
- 75 misfire damaging to cat coverter
- 63 cyl 1 misfire damaging to cat conv
- 64 cyl 2 misfire damaging to cat conv
- 65 cyl 3 misfire damaging to cat conv
- 75 misfire damaging to cat converter
- 68 cyl 6 misfire damaging to cat converter
- 66 cyl 4 misfire damaging to cat converter
- 67 cyl 5 misfire damaging to cat converter
- 62 misfire emissions relevant
- Ignition timing 6.75 °crk
- injection time 1.92 ms
- range 1 cylinder 1-3 (TRA)4.02
- range 1 cylinder 4-6 (TRA2) 0.10
- camshaft postion 1 deviation 9°crk !
- 174 camshaft adjustement bank 1
- 62 misfire emmisions relevant
- 51 cyl 2 missfire emissions relevant
Live data stream
- ignition timing 4.5° crk
- injection time 2.59 ms
- range 2 cyl 1-3 FRA 0.96
- range 1 cyl 1-3 TRA 3.94
- range 2 cyl 4-6 FRA2 0.91
- range1 cyl 4-6 TRA2 0.25
- camshaft postion deviation 25°crk !!!!!!!
- cam / crank sensor faulty
- Someone before me realign timing on bank 1 with badly worn out main chain guide or perhaphs faulty ims bearing (but no funny noises from engine) that why ex camshaft sporcket on bank 1 is at the end of its adjustement
- something else...
Best Regards
Marek Rybak
