Before I spend a billion quid on whizzing my 986 in for suspected double air con condenser replacement, I'm going to try one of those Interdynamics Super Seal repair and refill kits. It allegedly works in the same way as those puncture tyre seal aerosols but without the bath foam...
Anyway, the instructions say to connect it to the "low side service port" on the air conditioning system, and that if it is connected wrongly there is chance of servious injury if the can grenades.
There seems to be two valves to potentially connect it to, I assume the low side service port is the one that has the same size valve (the smaller of the two), but thought it worth checking on here to ensure that Porsche does not adopt the same upside-down approach to aircon valves as it does to PDK paddle gearboxes (i.e., the opposite way to which you would expect...)
