I have ordered a new Boxster 2.7. Until a couple of years ago I owned a 964. There were times when the car did not go out much and almost invariably after about 3 - 4 weeks the battery went flat. A friend who has a 996 has had the same problem. Is this an inherent Porsche problem (I have not experienced this with a BMW or Jag) and would I be advised to use a battery conditioner or consider a stronger battery. Mind you probably the best solution is to use the car a bit more!!
