Thanks Rob,
I have emailed autofarm with my original question. The reply i have included below. I haven't explored the prospect of 300bhp out of the existing engine. I think that this may be a good option. I shall find out the costings.
We've installed 3.4 engines before, see Dec 2001 911 & Porsche World.
To fit a 3.4 996 engine, which needs new special exhaust system and lots of other detail bits, parts and labour circa £3,000 + VATIf we'd everything to hand, should be able to do it in 2 weeks. Installing a 3.6 engine is much the same process, except the throttle control is electronic. You'd hence need the pedal assembly out of a late Boxster as well, I'd guess add another £1,000 + VAT parts and labour for a 3.6 installation.
We've a 3.6 engine in stock needing a rebuild, but no good used units, which fetch circa £4,000. Our unit fully rebuilt would be some £7,500 + VAT.
Unfortunately the 2.7 ltr engines have little value, and we could only make a nominal allowance against it.
We would need to investigate your brake enquiry further, but I'm sure there is a bolt-on upgrade available.
Hope this helps. Let me know if you'd like to investigate this further.
Best regards
Josh Sadler Autofarm
