Boxster Fault Code
- Thread starter suthe777
C13212
Diagnosis information Component(s)
LIN user
Diagnostic conditions
The control unit must be active in order to test internal function sequences and diagnosable inputs/outputs. In the event of a fault, check whether the fault is permanently >present<. To perform the check, erase the fault memory, meet the diagnostic conditions and read out the fault memory again.
Ignition on
Fault setting condition(s)
No signal/communication
Fault effects
The affected function no longer reacts
