BOXSTER FLAT SPOT!!
- Thread starter jdpef356
If that doesn't work then it'll be more efficient to run some diagnostics to get a better handle on the problem if it's ignition, injection or exhaust-related. I can't recall which version of Boxster you have but I seem to recall that (relatively rare) high pressure fuel pump problems on the Gen2 engines can lead to rough running.
Jeff
Motorhead said:John, I'd agree with Cliff - the MAF should be your first port of call. You could just try disconnecting it first to see if that clears the problem - the DME will revert to a default setting - but if you're already in there it's probably advisable to pull it out and clean it or maybe replace it.
Jeff
Thanks Jeff, on the ball as ever!
Steve Foster
