boxster immoberliser
- Thread starter Guest
if you're having intermittent problems locking the car or starting it, and it's acting screwy, like opening the front boot when you try to start it, then, as Mark says, check the floor under the passenger seat. If it's wet then you have blocked drain-holes and the OPC will tell you you'll need a new ECU and alarm controller (£800+).
http://www.porscheclubgbforum.com/tm.asp?m=227386&mpage=1&key=
