boxster key fob 986 model
- Thread starter heathview
The only scenario where the fob doesn't work and it can be reactivated is when the car has stood for more than 5 days and the locking system has gone into sleep mode - then all you do is unlock with the key and its activated again.
The stories to reactivate a fob are - remove the battery and reverse it in the fob for ten seconds, remove it again and place it the correct way, 2, lock the car manually- unlock it and press the lock fob button,3 place the key in the ignition, turn the ignition on then press a fob button - absolutely none of them work.
Its a common thing for sudden death of the remote - the fix is - buy a new one and have it activated at an OPC or independent Porsche dealer - around £200
