Hi all
I have two keys for my new (1999) Boxster. The remote functions work from one and not the other. Apparently the remote functions didn't work for either until one of the keys was used to unlock the car manually, then the key was inserted into the ignition and the ignition was turned on while holding the central locking button for 20 seconds. Then the ignition was turned off and apparently the remote functions on the key then worked. The remote functions do indeed work, but I've tried that routine on the second key and it does nothing. Also changed the battery and then tried again, still nothing. Tried the insert battery upside down trick, tried the trick in the manual, nothing is getting the remote functions to work on the second key. It does though unlock the car manually and start the engine, so it is the right key. Help?
