Boxster roof
- Thread starter xsx
My first thought being a fuse...
The motor is at the back of the are a the roof folds in to - so that makes it a little inaccessible at the moment if the roof is open [&:] I'm sure there is an emergency procedure in the manual for this?
regards
Black80XSA
When the roof is partly closed check the tensioning wires haven't popped off (they have a ball socket on them which can come loose). and if yo can get to it check the microswitch which detects the clamshell closure.
If you take a look you can see the button for the microswitch - try pressing this a few times to unstick it.
If the microswitch has completely failed (or a wire fallen off!) you can get in and replace it - but try this first.
Black80XSA
Black80XSA
ORIGINAL: Mark Bennett
I need to type faster...[]
me too [
ORIGINAL: Black80XSA
me too [] i was 3 seconds too late with my user manual suggestion lol !!
xsx - if the above doesn't work and you need to get the roof up - I can post the relevant bits from the manual - but let's see if this works 1st... ?
Black80XSA
ORIGINAL: bdheng
Mark
Would this switch "malfunctioing" allso cause windows not to close automatically when roof is fully closed. Mine stay down 2"-3".
Barry
Yes, they should close when you re-lock the roof latch.
