sbloxxy
Hi everyone. My Boxster is a 2000 model yr 3.2S. My wife is using it quite a bit at the moment and today after just 10 miles or so, she noticed that the temperature needle beginning to climb. She had been stuck in traffic but only for a few minutes. She immediately turned back for home with temperature gauge hovering just under the 100C mark and as she built up a little speed (60mph max), the temp cooled of a little.
Back home,I let it tickover on the driveway and the temperature fell closer to its usual position of just over the 80C mark.
Once it had cooled down, I checked the coolant: a little pressure released as I removed the cap which I reckon means there are no leaks (and no signs of leaks anywhere anyway) and the coolant was at the correct level.
I ran the car again, engine covers off and again no sign of any leaks. So I drove it around our village for 10 minutes and gave it a blast along the bypass with no issues and once back home, let it tickover on the driveway again. The temperature once again crept up to around 100C. However, I did not hear the fans cut in. In fact I even checked the fuses but all was ok.
Anyone got any ideas? The needle usually climbs to just over 80C and stays there and has alway done so, other than when stuck in traffic on a seriously hot day.
