Hi - can anyone supply me with a set of instructions showing position of fixings in order to remove the centre console preferably with photos. I need to adjust the handbrake cable after changing the rear discs & pads & can't find how to access the front part (I can access the rear part but that doesn't give sufficient access) Hope you can help.
Boxster S Gen 2 manual centre console removal for access to handbrake adjustment
- Thread starter rowtietowers
Trevor,
You may find this link helpful:
http://www.pelicanparts.com/techarticles/Boxster_Tech/42-TRANS-Short_Shift_Kit/42-TRANS-Short_Shift_Kit.htm
However, I'm not sure that you can adjust the cable length at the centre console. You may just have to adjust the handbrake at the discs like this:
http://www.planet-9.com/987-cayman-and-boxster-service-and-tech/27746-parking-brake-adjustment.html
Jeff
Jeff
Thanks Motorhead
Sorry for belated reply but had problems getting back in - kept dumping me out on my i-pad
In the end I took it to a local Porsche specialist and they adjusted it just using the rears discs (not touching the centre console) - now I know I'll do it myself in future
Thanks again
Trevor
Thanks again
Trevor
