Gentlemen, help if you can please.. Boxster S 2002 (986) which after a small(ish) shunt, has stood for a while without being started.
Now it wont start, Battery was flat...dead. took out the battery and re-charged, alarm went off on re-connecting and remote would not 'silence' it. After about 30 secs it stopped on its own.
Key remote will lock and unlock, Key in ignition lights up dash and engine turns over..but wont fire.
Heard from a neighbour, that flat battery means key/ignition module has lost its code and needs dealership re-setting...(thats going to cost !!).. is this right, or is there a simple fix.
Checked Relay in boot, swapped over with another, checked fuses, all seem OK..
any ideas my learned friends ...
Update on above.,,,Fuel Pump Relay faulty, found a thread on http://www.pelicanparts.com/techarticles/Boxster_Tech/22-FUEL-Fuel_Pump/22-FUEL-Fuel_Pump.htm very very useful website
follow the links/pictures to see how to make a small jumper connection to bypass relay.. did this and it fired instantly..
Thanks to Richard for his valuable input on this, he was bang on and it was a fuel issue. [
